Thanks again for your input. I've measured the wires of the CAM sensor, it all seems to be OK. It receives the correct voltage and even though I don't have an oscilloscope to see the exact signal it gives, I was able to measure that it gives pulses towards the ECU. The coil packs receive their 12V feed but don't receive commands to fire. I've tried testing this with a spark plug outside of the engine and I've measured it too just to be sure. The cambelt has been renewed recently, the only problem is sourcing the CAM locks for the Abarth engine. Here in NL this is seems to be mission impossible for some reason. I haven't tried asking the local dealer to loan them to me though. I can see in MES that the fuel pump is engaged whilst attempting to start, my sense of smell can definitely confirm this
I'll report back once I've made progress.
OK - glad you've backed up some of the electronic checks with physical checks. I don't like and try not to become too reliant on the laptop stuff as what the computers see and command doesn't always translate into the physical workings of the motor.
