Thread Tools
Old 17-03-2017   #1
Starting problem with 2.4 stilo abarth
Hi
So I had a problem tonight while working I went to start my car and when I turned the key to 'start' position nothing happened no dim in lights no warning noise no crank nothing, I then connected jump leads to the batter but nothing connected to the other end and it fired up first turn,
When I went to start the car again around 10 mins after it happened again but this time nothing would work, tried jump starting it with another car no luck,
I left it about half an hour and tried starting it again and it fired up stright away, I've checked the battery it's fine and it's really baffling me on what it could be any help would be amazing as I need the car for work I can't earn without it I'm a delivery driver so no car no work no money haha 🙈
Infinite is offline Reply With Quote Quote
Old 17-03-2017   #2
Re: Starting problem with 2.4 stilo abarth
Sounds like possibly ignition switch. Might be worth testing it.
Registered Alfaholic
Current cars - Stilo Abarth (let's not mention the Audi)
Previous: Fiats: Uno, Tipo, Brava (1.8 ELX), Marea (2.0 155); Alfas: 156 (1.8TS), 166 (3.0 V6), 156 GTA, 156 Sport (1.9 JTD M-Jet), 159 Lusso (1.9 JTDM), 147 Lusso (1.6TS)
Artermis is offline Reply With Quote Quote
Old 17-03-2017   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Infinite View Post
If it started with jump lead clamps connected to your battery, but not connected to another battery, it would suggest a poor connection between your battery terminal(s) and lead(s). Extra pressure of the jump lead clamps could have temporarily tightened the contact(s).
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 17-03-2017   #4
Also for got to add this but when I turned the high beams on last night while driving there was a noise as though a motor was struggling
Old 17-03-2017   #5
This is the noise
Old 17-03-2017   #6
Yellow Peril has donated!
Headlight height adjuster probably. Failure is a common issue...
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 17-03-2017   #7
Quote Originally Posted by Yellow Peril View Post
So I just found out if I pull the high beam on while the car has just the ignition on the car starts
Old 18-03-2017   #8
As in the pull of the light stalk replaces the need to turn the key and actually cranks the starter motor....?
Well if that's the case you have a fairly significant wiring issue lad. You could try and chase it down yourself but if it was my car I would have an auto electrician look into that one.
Have you do as Davren suggested and check your wiring contacts?
I would also suggest cleaning the fuse board that sits above the battery in case it's short through there.
Likes Davren liked this post
Old 20-03-2017   #9
Yep ifor I pull the stalk to flash the high beams the starter motor engages and the engine fires up, I took it to fiat and after much laughter the technician told me the dues board under the bonnet that sits above the battery is damp causing a short circuit
Old 21-03-2017   #10
Now that is a weird one, funny and dangerous at the same time.
If you have to flash your high beams then you could burn out the starter motor and blow other things inline with that... becareful.
dtimmins1985 is offline Reply With Quote Quote
Thread Tools
(T) Stilo Abarth Not Starting RichyRich101 Stilo 5 28-01-2014 23:11
(T) Stilo electrical problem + warm starting problem h2ypr Stilo 19 11-02-2009 18:35
