- Aug 14, 2015
- 24
- 7
My Uproad is due for a big service it´s done around 134000 km (83,000 miles) and seeing as the Timing Belt was last done in 2012 it´s time for replacing.
I have found a garage that´ll do the work for Labour only and I want to make sure I get all the bits I need.
For the service I´m going to order all the filters, sump plug and gasket, engine oil and I am going to change the gear box oil too.
I am going to order a Timing Belt and Waterpump kit either https://www.shop4parts.co.uk/?name=store&op=details&ProdID=13816&sku=253718
orhttp://www.mister-auto.co.uk/en/timing-belt-kit-with-water-pump/gates-kp55500xs_g3096_a033KP55500XS.html
What else will I need to order? Is it recommended to change the Aux Belt at the same time (and the tensioners as well)? I´ll need to order coolant as well?
Also on the last MOT an advisory was given on the brake hose connections being rusty. Looking at ePER I just need to order4 new hoses and the Brake Fluid?
What else would you recommend getting done at the same time?
Nick
Nick
