Hello.
So a week ago i decided to try myself in upholstery and i removed steering wheel to put it in a new leather suit. After putting it back on the airbag light turned on and of course famous stilo "airbag failure stop engine" appeared.
I figured i must have displaced clock spring somehow so i used a guide to recenter it but it didn't help. A buddy of mine used tester to delete a few error but "09" and "0a" remained.
http://imgur.com/a/Y0HX4
After searching forum for codes i found:
Yellow connector in glovebox - cleared -
09 Passenger squib circuit error 98
0A Middle passenger airbag squib 2nd stage error 114
so i cleaned connector near glove box using contact cleaner but the problem is still there.
http://imgur.com/a/6KvWn
While cleaning i also found connector with no home.
http://imgur.com/a/zyl3S
I would like to know how do i determine which airbag is the problem since codes aren't pointing out the steering wheel one (i think) and if there is a solution that doesn't cost me a fortune.
