Re: dashboard control module
Hi Sorry
i have been searching all day and have finally tracked it down to the circuit with the brown fuse F71
i looked it up in my owners manual and it stated it was the Dashboard Control Unit
when i disconnected the cable that ran to the fuse the battery drain dropped to 0.01
this is as far as i can go
OK... looking at the wiring diagram, it would appear that Dashboard Control Unit must refer to the Body Computer, not the instrument panel. The BC is the grey box attached to the back of the dashboard fuse box.
The thick red wire from the 70 amp fuse link F71, is the main power supply to the Body Computer (M1 on the wiring diagram) and the dashboard fuse box (B2). As well as supplying the BC, it also supplies numerous other consumers in the fuse box. Too many to list them all here, so I've attached the wiring diagram below.
If you follow the line (wire) from the 70 amp fuse, marked B and CPL1 on the battery fuse board (B99) across to page 2 of the diagram, you'll see all the consumers that it powers.
A few examples from left to right in the fuse box are:
Fuse F38 which powers boot lid locking on some cars. (On some versions it's a spare fuse).
Relay T12, which powers the front wipers via fuse F43, the cigar lighter via fuse F44 and the rear wiper via fuse F52.
Relay T1 which powers dipped headlights via fuses F12 and F13.
If you're unfamiliar with car wiring diagrams, the black dots at the junction of 2 lines means they are electrically connected. If there's no black dot, the 2 lines are not electrically connected.
To isolate you drain problem, you'll need to remove each relay or fuse that's supplied by fuse link F71 individually.
Post back if you have any problems.
