dtimmins1985
Established member
Hey up guys,
Had a bit more time to play about with MES today.
I have some airbag faults, when i bought the car it was all fine, no airbag light then two weeks prior to first MOT with me owning it and boom, airbag light came on.
It was intermittent and went off, then came back on and off a few times, after about 3 months of been off (no light on dashboard) - it came back and stayed since.
I have checked the codes in MES.
I cleared them and one has gone away, possibly caused when the previous battery went flat, but some other codes come back straight away.
I'll try be as clear and detailed as possible, if someone can tell me the HEX code for each airbag (which is which) that would be great.
1: 0F - Side airbag (passenger)
The reason for this fault is Open circuit
The current status of the fault is Intermittent
The error counter value is 156
Looks like the fault has appeared 156 times according the counter.
2: 09 - Passenger squib circuit
The current status of the fault is Intermittent / Present
The error counter value is 4
Looks like the fault has appeared 4 times according the counter. I suspect that this fault is the one that was intermittent and caused the Light to come and go in the past, the other faults are what is keeping the light on now, i think that according the values on the fault counter
3: 0F - Side airbag (passenger)
The reason for this fault is Value too high
The error counter value is 109
Looks like the fault has appeared 109 times according the counter.
4: 0E - Side airbag (driver)
The error counter value is 57
Looks like the fault has appeared 57 times according the counter.
Cleared fault codes and below i know have:
1: 09 - Passenger squib circuit (error count still 4)
2: 0F - Side airbag (passenger) (error count still 109)
3: 0E - Side airbag (driver) (error count still 57)
Checked the ECU today, all connectors and pins look nice and clean so doubt its that side of the connections...
Need to know what HEX addresses relate to which air bag in the car, will have a look at troubleshooting in eLearn and see if that tells me.
Any help greatly appreciated.
