Thread Tools
Old 13-06-2016   #1
1.2 extended head gasket leak
Hi got various jobs to get done on the stilo i.e. lower wishbones, gearbox/driveshaft oil leak but i also have a slight oil leak on what I would of called the rocker cover on an old engine but I believe on the 1.2 its known as the extended head, its right in the front left corner (if looking at the engine from the front) near the timing belt cover.
Reading on some forums/posts it mentions that you need to remove/replace the timing belt to allow you to remove the extended head, is this the case as looking at various pictures of the head removed on the punto 1.2 engine which Ive been told is the same there dosent seem to be a requirement to do so.
Anyone done this before and if so any tips.
cheers Carl
Will try and gets ome pics tommorow
stmterrace is offline Reply With Quote Quote
Old 14-06-2016   #2
Stilo Fanboy
nikiforos83 has donated!
Greece
Re: 1.2 extended head gasket leak
You can't remove rocker cover without remove timing belt...
Also you have to remove the inlet manifold or cut the brace that is attached to rocker cover
This is rocker cover
This is the engine block with cylinder head
...and the new seal for rocker cover
Side view
New timing belt, water pump , pulley
Before
After
nikiforos83 is offline Reply With Quote Quote
Old 15-06-2016   #3
Thats great thanks, couldnt of asked for a more straight and informative answer.
Cheers Carl
Old 17-06-2016   #4
How much of a pig of a job is the cambelt?
Thread Tools
(G) head gasket replaced now slight oil leak Peter034 Punto (Mk1) 4 28-03-2016 22:11
(T) Oil Leak (Rocker gasket or head gasket???) stayinfly Punto (Mk1) 38 05-04-2015 22:46
(T) Oil leak - Head Gasket? ozzy39 Punto (Mk2/2b) 15 07-07-2009 11:35
(G) Oil leak from head gasket camper85 Ducato 0 31-01-2007 16:15
