This morning I did a service on my Stilo Abarth, and she seems to be running sweeter than ever:
- Fiat 71736159 oil filter, which has 14 flats around the top, so I can remove it easily using my (cool!) Laser filter tool
- Crossland A20338 air filter
- Crossland C40161C cabin filter
- Fiat sump plug washer
- NGK BKR6EIX spark plugs, gapped to 0.9mm. Previously I was running BKR5EIX, but I've gone up one notch on the temperature scale, as there was just a little evidence of the plugs running a touch hot. The '6' rated iridium plugs seem to make the engine a bit smoother at mid/high revs and high speed, and a little punchier too.
- Fuchs Titan SuperSyn 10W60 fully synthetic which specifically meets Fiat's engine oil spec for our cars (Fiat 9.55535-H3) and - like the Selenia - has a max 20k change interval. I'd been using (very expensive) Redline 10W40 but am hoping the 10W60 will reduce oil consumption, although mine wasn't especially high even with the 10W40.
