I am sorry it is not my intention to hijack thread, I have searched and read till my head hurt but could not find answer to my problem. I will try to describe what I am experiencing as best as I can however I am not skilled car mechanic so some of terms I do use may be lame
First off, Stilo is a love of my life. I used to have JTD and loved it. My current car is 1.2 5 door 2002 model. Everything was quite fine with a car until one morning I have found battery flat. Didn't think too much about it and just recharged battery only to find it flat within 2 days. I do not drive much it is mostly in the city school runs, work say about 30 km a day. I thought battery is old so I recharged it again. I checked (removed and cleaned) all fuses. It happened in evening and when I connected everything I found that when I locked car and was about to leave when I noticed lcd panel on instrument cluster was still faintly lit and flashing at a a times. That seemed to be the problem, panel was flashing sometimes as bright as it is when driving.
I disconnected instrument cluster and left it disconnected overnight and every time when I was not driving. No more flat battery so I thought there was my problem. I removed cluster and while trying to remove display I managed to break it.
Well call me stupi* I have no objection as I felt exactly like that. Instrument cluster work even without lcd display only to see that flashing bit better (there are 3 orange diodes under display). I kept on driving I just disconnected cluster for the night to keep it from draining battery.
Here is my dilema. I got another second hand instrument cluster. I connected it and was ready to start to celebrate when I noticed that one diode stayed lit - green one for the lights even that they were off. I tried to start engine, turned lights on, off - green indicator stayed on all the time. It is also on even if I take keys out and lock the car.
I thought that if there is problem in wiring, connector or somewhere outside instrument cluster, that it will manifest itself in the same way like on my first cluster - flashing diodes under lcd panel. However while first cluster does that, second do not have any lcd diodes problem just that green lights indicator.
That makes me wonder -
what is the chance to have both clusters bad? Should I try to get another one or what to do or check now?
Sorry for my long post I tried to explain the best of what happened.
