Hi all-new to this forum, hope you can help
I have recently acquired a 2004 Stilo 1.9JTD and the first issue was that it kept giving a pre heat fault. I replaced the glowplugs and changed the large relay and still the same issue.
I ran a diagnostic (someone very kindly assisted me) and told me that injector 1 is the issue. I then got injectors (second hand-Tested and they were fine) and it still gave the pre heat fault in the dash.
I then changed all the injectors and when I switch the ignition on the fault is now gone ...yaaay...however the car wont start now. It simply turns over and does not start.
I have tried the priming of the fuel line (turn ignition on for 10 seconds a couple of times but nothing
Does anyone have any suggestions please. Do I need to prime the fuel line?
Thank you
Thank you
