Hi guys,
I know there are so many threads on issues with this message - believe me I've read every one I can find. Issue started mid Feb and I've been trying to fix it ever since.
Issues:
When it first happened I was starting to get some issues with the ESP - it sounded noisy when steering at low speed (i.e. parking) and also felt stiffer. This is no longer happening however. Also on 21st Feb (a few days after message appeared) issues went away with no errors until after about 40 minutes of driving message reappeared along with "Engine Fail" and engine management light.
After reading the forums first thing I did was replace the battery, the old one was going as if car was left for a few days it was dying. It now has a brand new Yuasa 093. I've tested voltage when running and it is 14v. It is definitely cranking a lot better but three issues above remain.
First garage I took it to after this said it was the cluster and gave me the error codes indicating this. They also checked all the earths and verified them as fine (I have since checked the gearbox earth and C15 earth and can confirm these are fine). I sent cluster to Cartronix for repair, when it came back I refitted it and issues remained. Confirmed with them that it is all working as it should and they had tested it their end after replacing main components (crystal etc) and it is fully operational.
Read on here that crankcase sensor is a good bet for this error occurring, I replaced this but no change. I bought a handheld code scanner and read off a U1700 code (CANBUS error between ECU and BCU) as well as the speedo failure error. Unfortunately error message from 21st Feb was not listed, as garage probably cleared it thinking it was irrelevant. I did phone them to ask if they had it recorded but they didn't.
Checked D4 and all fuses and relays at this point and sprayed with contact cleaner before refitting. I then took it to an autoelectrician in Swindon who confirmed the wiring between the ECU and BCU is fine and suggested the BCU needed replacing. I found a replacement BCU (same part number) and got the coding transferred at ECUdecode in Westbury. Again, no change.
At this point checked engine fuse box more thoroughly, realised some water had got in at some point. (Incidentally water can get through a gap in the top of the nearside inner wheel arch liner and can make its way up past the battery tray into the fuse box. Will find a way to seal this soon.) I took whole fuse box apart and found some corrosion, cleaned everything up with contact cleaner. No change. Replaced fusebox with better second hand one after checking each layer, again made no difference. Have also checked each fuse in both fuseboxes and none are blown. Also replaced every relay in engine fuse box.
I've finally booked it into Fiat in Swindon but they can't get it in until the 12th April, also service guy sounded pretty despondent. I really want to try to get it sorted before then!
Read last night that the ESP ECU acts as a bridge between the ECU and BCU. If that's right I'm planning to try another ESP unit (the breakers nearby has one, just have to finish removing it). After that I am well and truly stumped. Any suggestions appreciated, Matt
Issues:
- No speedo, tachometer, temp guage, mileometer, pretty much all warning lights on. "Loose connection" displayed.
- Lacking power - ECU clearly in limp home mode.
- Taking longer to start - have to crank it for longer but never fails to start.
