Hoping somebody can help or suggest possible checks which I may not have done so far. I have a Stilo, 1.8, 2005. The car went in for an MOT on the view if successful the car would be sold. The car failed its MOT on high emissions. The car has been displaying poor performance for the past week (week before MOT test), over the past week it appears to be using large amount of fuel, car idle speed varies, cuts out sometimes at slow speeds. Engine light displayed on dash, light is blinking.
Checks so far.
>Connected fault reader, code PO303 - Cylinder 3 misfire displayed.
>Swapped coils (3 and 4), restarted engine same fault code appears PO303.
>Checked spark plugs (changed 2 months ago), seem ok, slightly dark on the tip however look ok. Swapped spark plugs (swapped 3 and 4), same fault code displayed.
> Visual check done on wiring from coils on main harness back to ECU.
> All connections checked.
> Measured resistance on coil inputs (3 wire connection block), on all 4 coils I get around 3.4K when checking across pin 1 and pin 2. Assumed this would be in the lower ohms however with all of them giving the same result I'm assuming all coils are good.
was thinking of starting the car up and disconnecting each coil one at a time to see if this makes a change in the engine speed.
can I measure the input wiring for volts ? if so what would I expect and at one terminals ? presume if I don't get the correct voltage on one of them its probably the ECU. might measure all four and confirm if they all display the same voltage.
was also thinking about sending the ECU away to get checked / repaired (if needed).
should I check the injectors ? is this the same for testing ? check across them for a good low resistance.
any further ideas ?
Checks so far.
any further ideas ?
