Ragazzi,
My instrument cluster is zombified...
Occasionally it "dies".. the only things that work are the check lights that come on with the ignition then go out .. nothing else works, no back-lights, no dials, no indicator lights, no info screen... nothing.
When it's in this "zombie" mode, there IS power to the cluster.. otherwise the symptoms are the same as no juice to the cluster. The middle LCD panel says "Checking"... and the clock is stuck on the time when it became living dead .. e.g. "12:35" this time.
So it has power... just not getting its brains into gear. In the past the problem just randomly goes away and everything comes back to normal.
I have disconnected the battery in the past, to see whether that helped to clear the fault.. but it doesn't. It comes back on exactly as I left it... stuck at this "Checking" state.
Any ideas?
Ralf S.
Any ideas?
Ralf S.
