kernowstilo
- Jul 25, 2013
- 8
- 3
Hi folks,
I've started to remove the thermostat on my 2004 jtd multiwagon. The sticking point is the bracket that goes over the lower bolt. There is a 10mm nut then a bracket that is attached to something that says FIAT Valeo' on and behind that bracket is the 13mm nut to remove the thermostat.
My question is, what do i need to do to remove the 'valeo' thing, so I can access the 13mm nut. Hope that makes sense to someone and you know the answer please?
The rest of the job I can see what to do.
Many thanks nod.
Many thanks nod.
