- Nov 18, 2015
- 63
- 21
Osr calliper seized £95 for calliper & £25 to fit I'm just glad both don't have to be changedThe link that connects the 2 rear cables to the handbrake lever is designed to swivel, to compensate for uneven streaching of the 2 cables. However, yours looks like it's swiveled more than normal.
Could be that your right cable has streached too much, or it could be that your left cable, or the handbrake mechanism on your left caliper has seized. The left cable is know to seize more often, because of its more convoluted route to the left caliper.
Check that the levers on both rear calipers are moving equally while someone slowly pulls the handbrake lever up.
Clintwilbourn1994 you can get replacements cheap than that or cheaper still second hand to fit are easy as well all you need is a wind back tool and a spare hour swapped mine last year
Are theyStrange it's the O/S caliper that's seized. The position of the link and cables in you picture suggest that it's the N/S (bottom cable in your pic) that's seized. Unless the O/S one is seized in the on position, but you would notice that when driving.
Best practice is to replace both sides when dealing with brake or suspension parts. Probably doesn't matter so much if you fit a second hand one.
There's a pair of almost new rear calipers for £56 delivered on eBay here: http://www.ebay.co.uk/itm/151888313625?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Are they
For my car as mines 3dr 05 plate ml05vuv
Imo im with Davren thats a good price for both calipers and with replacing both no worries the opposite caliper will be givin in anytime soon
Are they
I'd buy a pair
Did I mention I'm selling some.
I'd buy a pair
Do you have them still ? How much ?
