I think i need to go back to college OR i cant see the forest for the trees.
In a nut shell i get blue smoke from exhaust when initially setting off from cold start, under heavy acceleration (>4500rpm) and intermittently after shutting off for roundabouts and then heavily accelerating.
My money is firmly on valve guide seals. One of the guys from work (a landy fan :yuck suggested piston rings. now im starting to doubt my own diagnostics.
Oil consumption is around 1.5liters every 1000miles or so, Cat monolith has suffered a meltdown, (which i initially put down to failing Lambdas due to it crossing the threshold of 100,000mi, because it was the cheaper option)
i am under the impression (be it correct/incorrect) that nowadays, oil control rings, to all intents and purposes, dont wear and its probably not going to be that where as valve guide seals is the much more viable option on a 128,000mi motor.
a set of rings seem to cost quite a bit (i was expecting £20/30 for a set, whereas its more like £20+ per cylinder, or atleast for the first few internet listings ive found). im about to drop £180 to get the rest of the bits to do Guide seals, cat and timing belt and am now wondering if i need to spend yet more money to get the rings + honing done. The wife is leaning on me to do it 'cheaply', i keep having to explain that getting it done once is the cheaper option but i can see her point since i dropped nearly a grand on suspension and brakes last year.
TL : DR... Car's broke again, Need advice!
