Hi guys, my '03 1.6 stilo is throwing up a loose connection error message on startup with the code u1702,and the power steering is'nt working,
This has been happening since about 6 weeks ago when i changed the engine,and i was putting it down to a connector under the fusebox near our friend the dreaded D4...
But as the fault would dissapear once restarted i left it till today to fix, because i have the (nct/mot) tomorrow!!!!but now it is happening every 2nd startup
Also since the engine change at startup occasionally i've noticed the speedo needles flicker to the max and i get a high temperature warning..???even when cold, however now if that happens i dont get the power steering fault
so far ive completely dismantled the engine bay fusebox,used contact cleaner on
all connections, any help welcome,thanks in advance.
