General Reg plate light wiring diagram
ellesmere port
Morning All
After searching though loads of posts etc, i cannot find a wiring diagram for the rear number plate lights.
I know there is not a fuse for them, and someone has put a feed from the unit (i have a split tail gate also) so has the button built in tothe reg light unit. someone in the past has taken it apart it and put a feed from the o/s boot sidelight. but i still get the bulb failure on the dash, so.. my question is would someone have a wiring diagram for the plug/loom so i can make the can-bus think they are working fine (which they are the way its wired now), i done this with my boot lock.
Yeah any help to make it think they are working the correct way.
Paul
Morning
An update on this thread and what i have done to try and solve this.
Re-soldered the light connectors inside the Light unit, the white plug/socket was faulty (pins not mating correctly), changed that. i still have the error on dash (bulb failure)
My question still is, like the boot open failure, you can join 2 cables so the canbus thinks the bulbs are fine/working.
Which ones do i link out/together to solve this.
car pin/colour: reg plate pin/colour
1-brown-------------------------Not Connected
2-Red----------------------------Purple/White
3-orange------------------------Purple/black
4-pink---------------------------White/black
5-white--------------------------Whire/Red
Pictures attached. (not the best was raining!
Any help would be great, another bulb and beep less on the dash!
Paul(y)
