Hi everyone.
Looking for some assistance with a number of issues and have lost the will to trawl my way through all the posts!
Some months ago I purchased a 1.6 multi wagon with the head gasket gone and airbag warning light on. Being familiar with Fiats and Stilos thought why not!? Had it on my drive where it started and ran for short periods without issue other than the airbag warning light.
Two weeks ago I completed the head gasket, ran it, bleed the cooling systems, cooling fan kicked in and then ran it some more with the revs up and all seemed well. It even started up again several times that day as I started to fix more mundane things like the rear wiper.
Since then it will not start and my fault code reader (SUN Modis) won't access the engine ecu through the Fiat software as it did during the post work run up but will through the generic OBD. Only code in there is one for an ac pressure switch.
The dash displays 'security system failure' 'loose connection' and the airbag which was already there.
There is no feed to the fuel pump and it doesn't even prime with the ignition. The remote works and the indicators flash as they did before and it cranks. I've charged the battery, a couple of times now and left it disconnected each time over night.
So, the question is, does anyone have wiring diagrams and location information for components and values and does any one have any suggestions on possible causes and solutions without going on a parts fitting exercise?
Secondly, the airbag faults are drivers side airbag squid and passengers side airbag squid. I've been trying to locate the connectors for them and have not been able to see them on either the A, B or C posts. I have demolished one trim in the process and don't wish to destroy any more! On my 5 door hatch they were conveniently located in the boot behind a panel. Cant seem to find them on this one! Any ideas where?
Thirdly, has anyone had a rear seat apart? The center seat belt has locked some how and I need to release the tension in order to allow it to unlock itself!
Failing that I have already filled my 20ltr jerry can and have a health supply of matches! It's getting close! If it doesn't start co-operating it will be sent to valhalla!
:bang:
:bang:
