Hello all!
I have a question for the experienced members to this forum.
Problem
- Vibration throughout the speed range (from 40 and up) especially around 60km/h and 125km/h i get a bouncy feeling in the car, not the steering wheel.
- At certain speeds it seems to be worse, the feel is when you drive a rough road.
- Over the past year, it seems to get worse.
What have i done?
As i am busy with this problem over a year now, i have tried a lot of things:
- New MAF
- Changed hose between MAF and throttle body
- Injector cleaned and tested (professionally)
- New reconditioned cilinderhead (with other cams/valves/variator)
- When cilinderhead was off the cilinder walls and pistons were inspected and all engine bearings (pistons out)
- Compresion ok and the same on all 5 cilinders
- Changed variator solenoid
- New spark plugs (5 pieces)
- New coils (5 pieces)
- Changed throttle body
- Changed ECU
- New engine mounts (3)
- Wheels balanced (a lot of times)
- Alignment doen (a lot of times)
- Other set of rims with new tires
- Changed drive axle left & right
- Inspected the differential & diff. bearings
- New left wishbone
- New wheel bearings front (left & right)
- No fault codes in all the ECU`s
- New PCV (positive cranckcase ventilation)
- Changed engine rpm sensor
- Changed Selespeed ECU (solved the jerky pickup)
- Inspected the front and rear catalytic converters
- Checked lambda values (post cat 0.5V while stationary driving)
As you can see i spent some time and effort in trying to solve this 'little' problem. But until now without any result, vibration is still the same (yes also with other rims/tyres )
Noticed
I am kind of lost now, which direction i need to look. What i notice at the moment:
- Replaced both differential axle seals two times due to leakage now ok, strange?
- Gearbox whine especially through 1-2-3 (you can hear it inside the car)
- no major play where the axles go in te differential
- Selespeed changing gear rough
idea`s?
- At the moment i am suspecting it must be somewhere in the gearbox / flywheel area. But i replaced the flywheel / clutch in 2010 (5 years ago ) Although maybe because the old Selespeed ECU was very rough / jumpy on pickup it destroyed the dual mass flywheel?
I thought i tried to log the 'Clutch travel' when driving. If there is a imbalance on the flywheel it may have impact on the clutch travel? below is a graphic of the clutch travel during stationary driving (engine speed vs clutch travel)
I see that the clutch travel during steady driving (around 60km/h) fluctuates between 15.85mm and 15.10mm (0.7mm difference) is it possible that any of you can make a log so we can compare the values?
And ofcourse if anyone has an idea....
Problem
What have i done?
- New MAF
- Changed ECU
- New left wishbone
Noticed
idea`s?
