Hi chaps, as some of you may of seen from previous posts, my cars been rather poorly lately! So Friday will be a very busy day replacing broken flexi pipes, bent anti roll bar links, both suspension arms and repairing the headlight mounts to then fix the headlight beam!!! Any tips to make the day more bearable!!
My main question really is do you have to renew the suspension arm pinch bolts and/or any other nuts bolts fixtures or fittings, or would it be fine to use them again? If they need to be changed, could someone possibly post the bolt/nut part number can't access ePer!! Or kindly give me the size and dimension and il look in B&Q!
Thanks all!
Edit***
Also, what's the process for aligning the bonnet, mine juts out at the passenger corner nearest the windscreen by about 3cm & is well offline at both front ends where the bumper meets the wings.
Thanks all!
Edit***
