Technical Cruise control problem + off market radio steering question.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🎵
Hello there,
To start off: I'm not very technical with this kind of stuff but I'm willing to try and learn. :)
I've got 2 questions. The first one is that my cruise control isn't responding. I can click and push all the buttons I want but I don't get a light on my dashboard nor the cruise control goes on. So I guess some cable or some stuff is broken? Or something from the fuse box is loose or needs to be replaced? I don't know.
2. I've got a stock radio on my stilo and buttons on my steering which I like a lot. But I want a off market 2 din radio with gps and at least USB. Something like this one:
http://www.lightinthebox.com/nl/6-9...d-fm-atv-ipod-rds-microfoon-gps_p1658071.html
But all I need to know is does the kabels on the steering buttons fit/work on something like this? Or do I need something else for it?
Thanks for the support!
My cruise control stopped working. Turns out my brake light switch needed resetting as my brake lights were stuck on. At first it stopped my cruise working and then the light went off the dash altogether.
Get someone to check your brake lights are working correctly.
Yep mine did same thing brake light switch can stop the cruise control
It is possible to map the stilos steering controls to an aftermarket head unit but only certain units and you buy a little converter box that translates the signal
Sadly, my brake lights works. I can tell when I park in the dark. :(
Yes so did mine im not sure whay causes it - brake lights work fine even though it stops cruise control
