- Mar 1, 2013
- 64
- 15
Whilst changing the axle spiders (inner CV joints) on my JTD115 this weekend I found that the diff axle (the 'pot' part where the spider slides into) had quite a lot of play in. Am I right in thinking there is a tapered bearing behind the oil seal which can be shimmed to take up the play, or is that just on the petrol engines?
If so, is it a case of just removing the diff shaft, prising out the oil seal and adding a thin shim to take out the play? Can it all be done in situ? I assume the shaft will slide straight back into the diff after?
How do you remove the diff shaft, does if just pull straight out? Any clips or anything holding it in? Obviously I'll need to remove the gb oil.
Also is there only one size of oil seal and shims? The spider I was sent for the drive shaft was too small for my shaft, (24 tooth spline instead of 26) and it appeared it would suit a smaller driveshaft, do I need to make sure the oil seal and shims suit the diameter of my driveshaft? (Are there 2 different diameter driveshafts?) I gather the OS and NS oil seals are different too, is that correct?
Is there anything else I need to change at the same time whilst doing this job? any other seals etc?
I really appreciate any help or advice anyone can give me with this. If there's a guide or photos of this procedure anywhere please direct me to it, I had a good look but couldn't find anything relating to the JTD diff specifically. Thanks very much.
