Liamdownes123
Engine Fault and loss of acceleration
Hi there having quite a lot of trouble with my Fiat Stilo 52 plate 16v,
Started off a couple of months ago when the engine Management light came on when a technician came to look at it he found a fault with the spark plugs so changed them then it was ok for a few weeks
A few weeks later it happened again but started loosing acceleration and loss of power couldn't go any faster than about 15mph
He came out again and cleaned all the system out and went through all the computer system reset the ECU and everything ok
Literally a few days later lost acceleration on the motorway so ended up having a throttle box replaced then it drove ok for a few weeks
Then started again Engine Failure and loss of acceleration but he couldn't find a fault so it had 6 hours work on it checking the timing but everything was ok since then it has been doing this everyday cant get down the road without it going but it has now started racing when idling
if anone can give me some advise cause without it faulting i cant really do much otherwise its going to be time to get rid of it unfortunately.
