osvaldocm26
- Oct 19, 2013
- 59
- 16
Hello people!
I need your expertise once again. A few days ago this noise appeared out of nowhere. I just started the car and it was there. I took it to a mechanic and they where not sure on what it is, but they mentioned the piston bearing.
The sound is stronger the more throttle I give it and the lower rpm are. For example: 3rd gear at 1000 rpm. The more throttle I give it, the louder it sounds and fades away as the rpm climb up, disappearing at around 1700-1800 rpm. This happens with all gears and when revving it up in neutral it doesn't sound at all. Only at idle.
I'm sorry for the bad explanation but it's hard to describe the noise.
By the way, power and torque are the same as before, but engine vibrates more than normal.
[ame="https://youtu.be/mU_-beVVf6k"]https://youtu.be/mU_-beVVf6k[/ame]
Hope you have some ideas on this issue because I don't want my Stilo to die!
Thanks!
Thanks!
