Hello all,
I'm going to attempt to change the brakes on my fiat stilo. I thought I'd attempt the front ones before the rear ones. Is there anything unusual/special to look out for?
Is it as simple as:
1 Remove wheel
2 Turn wheel to the direction of where your working
3 Remove the two 13mm bolts behind the calliper
4 Remove calliper
5 Unscrew the two bolts holding on brake disc, remove disc and put on new
6 Pop out brake pads
7 Push piston back with c-clamp and put in new pads with brake fluid cap off
8 Put calliper back on disc and attach bolt.
Are the rears as easy/similar?
Any tips on getting the rusty bolts off? I sprayed them with wd40 and gonna leave them a few days.
Thanks in advance.
Is it as simple as:
1 Remove wheel
4 Remove calliper
Thanks in advance.
