Technical Help me figure out my acceleration problem (Stilo 1.6 2004)
Razon
After starting the car, it is very slow, barely moves, sometimes stalls completely because it doesn't respond to the throttle, like it doesn't get air or something. After a few seconds it randomly jumps from 1k-ish rpm to 4k and the car accelerates like a rocket, then it stalls again the next intersection.
Diagnostic shows no fault codes, spark plugs are brand new, cam belt replaced, throttle body cleaned, ECU repositioned, I suspect the MAP or Lambda sensor, here's a graph I recorded when I was driving around with a warm engine (the midle part is when I let it idle, around 750-800 rpm):
This strange issue mostly happens when the engine is cold, but multiple times it stopped responding to the throttle (revs don't go up, but not down either) even with a warm engine.
I may have figured it out after months without luck.
I disconnected the map sensor and the car runs better than ever, even in -8°C temperatures.
Now the question is, was the map sensor broken or is there something else going on? Should I replace it? Will I damage my car without a MAP sensor?
