dalemultiwagon
- Oct 31, 2005
- 44
- 22
Bought a stilo for the other half and finally just got it on the road.
I've been running it around myself for last month as I don't trust it, I keep getting (car security loose connection fault) basically it never fails to start from cold, after a good run and its upto temperature if I switch it off at the level crossings while waiting for a train or when we have just filled up with fuel it won't start. It's done it around 5 times in 3 weeks covering 1000 miles. It starts after around 5 mins or less of trying after its packed in.
Its always happened when it's switched off for a short period of time and never after been sat for a while.
I've checked over the wiring and connectors in the engine bay fuse box. I've swapped the engine bay fuse box and relays for a good spare one I had and checked wire connections into engine bay Ecu, I've also tried spare key I have but still get the same problem.
Has any one any other ideas what to check next?
Many thanks.
Many thanks.
