tuckermoto
- Jan 7, 2015
- 36
- 17
Hi All
Fan now running.
The fan had a split fins and when it was replaced back into the heater housing and the speed was increased it jamed up ,,,blowing the relay and the fuse.( I bought the car as a non runner ).If you are going to replace/take out the heater blower fan this is how i done it.
1..take the the trim away from the drivers side ..it runs from the chair to the heater
2..unbolt the pinch bolt which is located on the top of the steering rack as it enters the car in the floor and cable tie it out of the way.
3..press the clutch down to the floor and cable tie the pedal so it stays like that.
4..on the L/H/S of the clutch undo and remove the locking nut and tap the spindle back through so it is flush with pedal
5..then undo the 3 bolts holding the heater fan in the housing and with draw the heater fan motor take it out with the rear of the fan facing you it is tight and will come out just take your time...do not to forget to unplug the power lead before you with draw the motor fully
6..replacing is the reverse of the above
Fan now running.
