Technical cylinder head screw
misu
Member
Hi, I have a problem in my stilo 1.4 cabac two screws that catch the cylinder head to the right side rocker has worn threads in cylinder head and the two screws screwed and I can not escape a little oil down the right side cover gasket, which I could do in this case ..
Hello..do you mean rocker for the cam or do you mean for rocker cover or upload a pic may help.. think you may mean for the cover and one idea would be to have the threads helicoiled which if you have not experienced before is to drill the old thread slightly larger and put a thread insert in , make sure drilling area is well protected from metal parts from drilling and do not get into head area, you can get kits which include drill bit and heli-coil inserts with a tool to wind them in, unless there are better ideas around.
