Okay first off hello and sorry for this being my first post and it`s a help me post :bang:
Okay we have an 04 fiat Stilo petrol 1.4 5 door with 72k on the clock. Over the past 8 month we have started to have a few electrical inconveniences . It started with a erratic temperature gauge which developed a mind of its own. Unfortunatly it past its craziness on to the fuel gauge as it was not long before they were both showing incorrect readings or nothing at all. This was a pain but the trip computer and the low fuel light still worked and that meant it was an irritant more so than an actual problem that need attention. The rest of the dash is fine.
So far i have cleaned the earths on the passenger wing and the firewall and checked the ones on the battery terminals, all seem good only 0.01 of a volt out. can`t see it being a fuse otherwise the rest of the dash would be dead or am i wrong ? its worth noting that the temp gauge will work from time to time but the petrol gauge never moves.
Then our new problem which really is a problem struck, we lost the heater fan, this is a problem that needs attention as it`s bloody cold at the moment :bang:. I have located the fuse for the Fan which I think is FO8 in the engine fuse box and this looks fine (think that is the only fuse).I have read on here that it could be the regulator switch bit this normally fails in stages , ours just stopped working this is inclusive of setting four. I have also read the fan motor can fail which can blow the fuse but our fuse is fine. I think I have read that the fan speed switch can also fail which it could be I guess. is there anyway of testing first though
Once again thank you for any help and I will follow up this thread if we manage to fix it so that it can fully help others in the future
