My car just failed its MOT on two things:
* Nearside rear rear brake recording little or no effort
* Nearside rear brake cable has restricted free movement
Now, the handbrake has never been very good in the 4 years I've had the car, so I thought that was fair enough. I have replaced both cables and am after some advice about adjusting it now they are new. I have tightened up the adjustment nut in the car a fair bit, but the offside wheel still seems to rotate relatively freely. I got the wife to put the handbrake on whilst I watched the caliper, and the thing on the back of the caliper (technical term!) seems to be working, it's just not pulling taut enough to hold the wheel. The o/s wheel is held nice and tight. Oh, and the calipers, discs and pads were all renewed around 18 months ago, so there shouldn't be any problem with these.
I have tried a couple of the methods I read about on here to reset the auto-adjusters, but it doesn't seem to have made any difference. Should I just tighten up the nut some more? I'm scared of stretching the cables!
The other thing I wanted advice about is that the MOT tester seemed to suggest that fitting new handbrake cables would address both of the failures. I can't see how it would cure there being "little or no effort" recorded on the n/s rear brake. Have I got this wrong? Any explanation would be appreciated. Both sides (discs and pads) seem to be wearing evenly.
This is the first time I've had to replace handbrake cables, though I have replaced pretty much all other brake parts in the past, so I am reasonably competent!
