Kennif Fiat
- Mar 24, 2010
- 42
- 13
Hi, my 2004 active sport 1.6 failed to start after I fixed my washer motor, (dirty connectors) I checked a few fuses and took out one of the relays from the fuse box behind the battery tray before finding the corroded washer pump plug. Could it be I disturbed something?
Maybe a faulty relay or I disturbed the crank shaft sensor causing the engine not to start. It whizzes over fine but doesn't even try to fire.
Seems too much of a coincidence to be the ecu throwing up a fault after I fix the washer motor. It didn't start after so I'm hoping it's a quick fix.
It's never been a problem before, incidentally I didn't notice any warnings on the dash.
Any ideas welcome. Cheers ken
