| Ex-Stilo Warrior | Version code and Chassis No on Fiat Stilo Hi there Where can I find the Code (4 digits) Number and Chassis Number (8 Digits) on my second-hand Fiat Stilo? I've looked at the aluminium plate under the bonnet, but there are a lot of numbers on there. I was just wondering which is which. Thanks for any help. Regards Superleccy 1.8 3 Door Stilo, 2002, Black
| If you look at the plate under the bonnet, the info on the plate is as follows from the top down: Manufacturers Name Homolgation No Vehicle Type Code * Chassis No Max weight Max weight with trailer Max weight front axle Max weight rear axle Then the engine no, body verion and spares code - but these are all labelled. The other place to look is under the little plastic flap between the driver's door and the driver's seat. In here is the model no (ZFA 192000) and the chassis no again. Let me know if this is not enough and I scan in and post a pic of the plate. Roja 2003 Silver 3-Door Abarth
| | #3 | ||
| Ex-Stilo Warrior | That's great Roja... many thanks!!! Cheers Superleccy 1.8 3 Door Stilo, 2002, Black
| running lumpy and cracking the code | sarahsea | Lets Talk FIAT | 3 | 26-03-2003 02:29 |
