Hello,
I'm wondering why some early 1.6 engines (2001 model) use Paraflu 11 (G11), while others (like my 2005 model) use Paraflu Up (G12).
I know you shouldn't mix G11 and G12, it's really bad, and one should stick with the recommended Paraflu brand. But could I use Hepu G12 or (violet) G12+, as they cost the same, about half the price of Paraflu around here ?
Has anyone tried violet/purple G12+ coolant, is it ok for the plastic and rubber hoses ?
How many liters of coolant do you need ... and is it possible to flush more than 80% of the old coolant (so I hear) ? In the manual is says 6.55 kilos (not liters!) so ... 3 liters should be enough + 3 liters of distilled water.
Thanks !
Thanks !
