Wow! Thank you, man!
That's what exactly happens:
If I fit a new F31 fuse everything works 'till I connect my reverse gear. Then my (not automatic climate controll) stops working, my radio stops for a couple of seconds and, of course, the fuse blows. I am 100% sure that is something about my reversing lights and I am going to take a look tonight and tomorrow, and I am going to look for shorts on the connectors (like melted or something), but I saw a couple of italians in a italian forum that had exaclty the same problem. One of them said that his problem was in the reverse light switch on the gearbox. It was soaked in oil and the internal seal in the switch broke, causing a shortcut. Bu, that kind of swtich is just a switch that make two wires having contact to each other. Or am I wrong? Anyway, my italian is not the best
and that's what I understood from that story. I saw somewhere else that even the cigarette lighter light can cause that kind of problem, and like I said, I also HAD problem with my cigarette lighter (but its light still doesn't work because it blew and that doesn't botter me much).
Making shorter:
I am going to check the connectors and try to follow its wire untill the reverse light switch;
If I don´t find anything wrong, then I change my reverse switch;
If both doesn't help, then I'll check inside my central console for a short somewhere.
Anyway, THANK YOU VERY MUCH and I'll keep you up-to-date about my case.
Sorry if my english is not the best and I'll give you credits if I solve my problem.
