Hi guys was changing my indicator bulb got that sorted but had to loosen my washer bottle and did not re tighten it now my washers don't work has this anything to do with it I'm probably being stupid
For what I can make out F43 fuse what is in the dash. 30amp. Look at page 197 in handbook for fuse location. Download the book at the top of this page if you don't have it.
could also be that when moving the washer bottle to replace bulb you knocked one of the connectors of the pump or the connectors on the pump need a clean up ..the pump is also only a push to fit item into the washer bottle and sure you would of noticed if there was a big puddle of washer fluid on the floor.
Who know's what he keeps in it but I certainly not taking a drink from it....
Just a polite way of reminding chappie to check his bottle has some of the liquid stuff in it before ripping anything made of metal in the engine bay out to try and fix it
Hi guys
Right pulled the fuse and replaced it with a better one as the one I had in was a cheap rubbish one pulled the pump out and cleaned all the contacts up with wd40 and bosh had to fill it up with screen wash as all of it had flooded out its now working that's for the info
