Hi, new here and looking for help.
I bought a 53 plate Stilo 1.9 JTD Dynamic a few days ago, everything was fine but then had a big loss of fuel (1/4 tank in 8 miles) on return from work yesterday that turned out to be a split in fuel supply to the injectors.
I've replaced this line and everything was working fine but on drive last night I got engine warning and the car cut out completely. Under the bonnet there was burning smell around the fuses and various issues, headlights would not switch off, cooling fan on.
I'm assuming that diesel got sprayed over the area and has burnt some contacts so took it all apart and tried to clean, fitted new relays and and maxi fuses but now the engine won't start.
I'm getting the fault car security loose connection, the engine will turn over but not start. Also the headlight issue is still there in that I can't turn them off.
Looking for any ideas on things to check and fairly cheap repairs as it was only a cheap buy, if you think I'm better to cut my losses please say, I don't want to throw money at it and not fix the problem, even tho I do like the car.
All help much appreciated
