Technical wet fuse box jtd 80
ah ha the number on my fuse box is 51724393 which is further down the list under 2 branch control unit so a trip to the local fiat breakers later and see what i can find(y)
Good. I was thinking afterwards, why there is a number 1 and number 2 for those boxes. Maybe number 2 is for RHD v LHD or no. 2 supercedes no.1. Anyway, sounds like you've found what you need. Happy hunting.
  • Like
Reactions: saw
its sorted now 115 fuse box obtained split it & re-configured some of the pins also noticed that a 7.5 fuse had blown this was changed as well, started off a jump first time
The 115 version has an auto bonnet close function for when it rains when tinkering with the brakes..:)
Good you found a part with not too much hassle..now you be able to be able get out to test them brakes...
  • Like
Reactions: saw
yeah maybe look at a cover now as well :rolleyes: as for the brakes some air in system as it turns out so a re bleed is on the cards maybe no in the rain though (brakes work but pedal moves slowly when pressed)
