General Rear Passenger Door
Scotland
I will be swapping mine at the weekend as mine is rippled quite bad. Is it just a case of swap over or with anything need done like re calibrate the clocks or whatever its called, you know like when your total miles flashes when swapping clocks over.
Can't recall there are nodes in the rear doors, so I don't think you will have to proxy-align with the body computer.
This might come in handy:
https://www.fiatforum.com/stilo-guides/196933-5d-stilo-rear-door-dismantling.html
Cheers mate I seen that before when I was going to try and push the ripples back. I ended up with a half day today so just went for it. The trim and colour was identical so easy swap.
