AdrianInFlorida
I'm in the process of troubleshooting the usual "Loose connection, security, alternator failure, ASR Failure," etc stalls.
I've taken the ECU apart, checked the pins closely and found no broken solder, (not sure about the ball grid under the microprocessor).
cleaned all connectors (D4 and fuse box plugs) and rebuilt the fuse box
checking the grounds today, I noticed something I think might be odd, let me know if I'm off track.
Started the car and did a voltage check across the Negative terminal to most of the earth wires that I could get to. None of them showed much, if any, voltage, indicating good ground. Checked across the negative terminal to the little ground wire on the ecu and was seeing voltage there 0.25 or so volts) and between the negative and the ECU chassis itself.
My question is shouldn't those points, (ECU chassis and ECU ground) read 0, or at least miniscule, voltage when the engine is running , otherwise it indicates a bad ecu ground, right?
