Is there any problem if I didn't totally released the handbrakes cables?
I managed to push them back without doing that and it works fine
I found it pretty tough rewinding the piston. Much easier to completely remove the caliper, get someone to stand on it (or put it in a bench vice if you're lucky enough to own one) while you rewind/push it back. The only problem is, you have to worry about bleeding the brakes afterwards but its pretty straightforward with an old bottle, a bit of hose and a helper!
And how can I correct this now? The adjusment of the handbrake?
