Just wondering if someone on here is able to help me with the correct part.
I am still having squealing problems after replacing all belts and even a brand new crankshaft pulley.
My local Fiat specialist thinks it's "probably" the automatic tensioner that's causing the problem.
I have looked at the part numbers on the fiat eper but I see 2 tensioners (tighteners)
They call one a fixed tightener and the other an adjustable tightener.
However when searching for these parts they seem to both be called different things, so was just wondering if anybody could shed some light on what the correct part for me to order is? Which one is likely to cause the belt to squeal by not correctly adjusting the tension.
The 2 part numbers are:
Fixed Tightener: 7740252
Adjustable Tightener: 46750224
Thanks to anyone who can help
