vitaqo
- Oct 21, 2013
- 34
- 11
Hi guys!
I have problem with my Bravo (192A800 engine), so this is an off topic. On Bravop forum i didnt get help. The problem is the:
Error code 1206, you must clean or replace the DPF.
The car was slow, and i couldn't reached the 3500rpm.
DPF clogging: 96%
The error is OK, i understood. BUT! After a regeneration the clogging was below 80%. I used the car on 4500-5000rpm, for 30km and the clogging was below 27%. After a second regenartion, the dpf was clogged, more than 80%. How it is possible? Iam driving 100km/h in 5th gear. Or i use the car badly? I should use in 2000-2500rpm? Or a sensor is not working?
The question is, after a long run with 4000-4500rpm (20km) the clogging was 21% below. after 30km the clogging is 76% (4th gear 2500rpm). I dont understand what parameter says the clogging percent. The differential sensor? Maybe it is wrong?
Thanks for the help!
DPF clogging: 96%
