Technical Rear bush replacement
ended up using gas axe to get old ones out and the Nike puller then pulled the bush 3/4 of the way in before bar snapped at 200+ bar then i discovered bush ends so out of shape another new one is required
just end caps gubbed so just fitted em anyway.as the bushes are incorrectly fitted I will see how long they last BUT what a difference it has made
