Xavstack
- Nov 30, 2013
- 28
- 7
Hi all,
I've just spent about 2 hours trawling through the various decent posts on sky window problems but reckon I can't find a case like mine. It's hard tell if my issue is with the control unit or the blind/curtain position or motor. Here's an attempt to present my issue :
1. Initially the blind stopped closing properly, it would stay stuck about 3/4 back, over the passenger seats. No adverse affect on the window itself which I used for 3 months without touching the blind.
2. After a stint of my wife driving the car, I discovered the blind guides (small side rods in pics below) in the fully closed position whilst the blind had disconnected and wound back behind the upholstrey and the rear of the car.
3. The window continued to work but clearly it wasn't the same, sometimes getting stick in certain positions, mainly though, it wouldn't really do intermediate ones, managing nonetheless to open and close fully. The blind motor was making a horrible fast clacking sound and still does.
4. I lent the car to a friend (can u see the pattern?) who said he couldn't close the window but then managed to somehow and couldn't open it again. That's where I'm at now.
5 The only button that gives sign of life is the 0 position on the control unit which when pressed in makes that nasty loud clacking or clicking sound at the rear. The blind guides are stuck up front (closed), can't figure out how attach the blinds back to those. The blind buttons do nothing, nor any other position on the main dial.
6 Winding the window open manually does work, then closing it by holding the 0 position down to override, in steps till fully shut.
- Why won't the position dial even make an attempt to open the window slats? Even my key wont attempt, as if there was an electronic issue rather than a mech one.
- How on earth can I refit the blind to those guides ? Any way to move them back?
- Is that loud noise due to a broken part, related to the Bowden wires ? Why should the windows be affected now if they weren't before?
Thanks in advance for any advice all.
