Thread Tools
Old 25-08-2014   #1
Rear Bush Questions
yes this ol' chestnut...
i'm weighing up my options. do i...
A) go for standard fit silentblock/hydraulic/oil filled bushes and fork out 40 for the tooling?
-OR-
B) go for a decent quality aftermarket bush (namely Meyle HD) with a 4yr warranty and not worry about a tooling cost as they'll most probably be a rubber type replacement and i can 'slip' them in with a socket?
this never really works very well on forums but if option (A) does anyone have the tooling they could lend me or sell me for <20?
i understand the bushes have to be fitted a certain way (especially with the 'oil filled' type) im assuming i would have to compensate for a 30mm drop?
finally i know the rear axle is supposed to flex under cornering which creates a kind of toe in on the rears to aid with stability of the rear during cornering. would fitting aftermarket bushes hinder this or should i really be going for the 'oil filled' type?
Rich (Stain)
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather
OBD2 Diagnostic Codes
Throttle and MAP Relearn Procedures
richydraper is offline Reply With Quote Quote
Old 25-08-2014   #2
Moderator
Davren's Avatar
Trader Rating: 3
Davren has donated!
Re: Rear Bush Questions
The Meyle HD bushes are a copy of the originals so would still need the same tools to fit them with.
A mark on the bushes has to be aligned with a weld line on the axle. It doesn't matter whether the the car is lowered.
All aftermarket rear bushes are oil filled hydraulic bushes, the same as the originals. The rear suspension is designed to work only with that type of bushes.
Thanks richydraper thanked for this post
Likes richydraper liked this post
Stilo Parts For Sale:
Connect Nav+ Map Discs - Wiper Motor (NEW) + Croma Turbo i.e. Badges.
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 25-08-2014   #3
cheers Devran... as usual, excellent reply!
i'm thinking if any one has the tooling to remove/install the bushes i probably wouldn't even need to borrow it. if anyone could provide accurate measurements i could bodge a set together
Rich (Stain)
Old 26-08-2014   #4
sussexa has donated!
I found the fiat bush tools part numbers in threads long ago and was in process of pricing or ordering but didn't go any further.
ill see if I can find the part numbers again. they weren't very expensive, but was not certain which parts matched numbers.
these were some eper numbers I cross referenced to fiat numbers
2000007800 was 34.00
2000000200 was 5.57
2000000300 was 4.64
none were in stock and as said cant remember what tools they related to(just found my post it note when I rang for prices/stock)
just checked eper again some prices up some down 16, 6 and 6 at minute
here is the thread showing tools shape design etc I think that's where I got on trail of part numbers
http://www.fiatforum.com/stilo/24897...ar-bushes.html
sussexa is offline Reply With Quote Quote
Old 03-09-2014   #5
im going to get a hydraulic puller as it would come in handy on other stuff
stilo Resurrection tecnician (for a bit then back to gearbox wrestling ffs)
saw is offline Reply With Quote Quote
Old 18-09-2014   #6
Quote Originally Posted by richydraper View Post
have you done the bushes yet?
Old 18-09-2014   #7
Hi #Saw ,
not done mine yet. my plan is to hacksaw the old out and press the new one in
The 3 legged tool is 22.97 from Fiat. My local says its available for next day delivery with the part number of 2.000.000.400.
I think i can get hold of a hydraulic tool to ease her back in again, i fear ill have fun resizing the bush to fit though dont have a clue where to go to get it done.
Rich (Stain)
Old 18-09-2014   #8
bri1232 has donated!
They are easy fitted if you have the correct tools, Check out the guides
If I remember Shadeyman done a guide.
bri1232 is offline Reply With Quote Quote
Old 18-09-2014   #9
it does seem a relatively 'easy' job to do its just a lot of work.
the more i read through shadeys posts and the more i talk to people about it the more i scare myself.
my ONLY worry is getting the new bushes fitted correctly and whilst it seems straight forward, the fact that more than 1 forum member has had to machine down the outer sleeve of the bush just seems counter productive to me but its been explained to death on here and ive come to accept that the axle is good for maybe 1 repair in fiats eyes, due to the stretching of the axle eye when fitting new bushes. ill bet my bottom dollar the bushes have been done on mine but have no proof.
Rich (Stain)
Old 18-09-2014   #10
Ive done 2 Stilos using Fiat bushes no need to modify bush.
Old 19-09-2014   #11
Romania
Stay calm that eye does not stretch enough.. you will see when the bush gets stuck mid way.
Even if it would stretch it would be very easy for manufacturers to just make a slightly bigger one.
I helped a friend replace the bushings on 2 stilos. He has done many more and never needed to machine down the bushings. What i would say.. you need a really strong bush puller. or a high tensile strength bolt and a nut
aurick86 is online now Reply With Quote Quote
Old 21-09-2014   #12
weel i fuct one of my new bushes today job stopped.
Old 21-09-2014   #13
Romania
Quote Originally Posted by saw View Post
Did you use the special 3 prong tool for the bushes?
Old 21-09-2014   #14
Quote Originally Posted by aurick86 View Post
no Aurick hydraulic puller used by the truck fitter at work it pulls about 50 tonne, Fiat bushes however do not. are you saying 3 legged puller is better?
Old 21-09-2014   #15
I think hes referring to the tool with 3 prongs that sit in the 3 notches in the bush, so it only pulls on the outer and doesn't strain the inner during the pull in process, not as in 3 leg pullers.
Likes saw liked this post
Thread Tools
(T) Rear Bush nikkiy9 Stilo 2 26-04-2012 18:46
(G) help please rear sub/bush & rear radius arm bush bbkmrc Multipla 4 12-04-2012 01:12
(G) mw rear bush change roy lovelock Stilo 3 14-03-2012 13:17
(T) Mk 1 rear subframe rear bush replacement Jano Punto (Mk2/2b) 3 06-10-2008 08:27
(G) Yes more rear bush hassles!!! jamiewilson Cinquecento / Seicento 5 12-06-2008 21:42
