multihull
Member
Hi, back again
Stilo JTD just 04.
Had an intermittent (twice) immobiliser icon ondash, car while moving it still ran.
Have posted and had several responses which have led me to suspect the ECU as at fault.
Contacted Acutronic who on getting description of problem asked that the "Arial, Transponder & Immobiliser box" were all returned with the ECU.
Have the whole area around the electric PAS totally clear of any trim bits. Can locate and will remove transponder and aerial - but where is the immobiliser box. The wires from the transponder go over the steering column and then go into a complete loom. This seems to go into the engine compartment and cannot feel any exit wires (I am probably wrong). There is a black box next to the fuel filter which I have not removed yet (a bit more stripping down first).
Can anybody confirm that this is the immobiliser. Or can anyone give a good description of a immobiliser box. All info appreciated.
A compounded problem - I took the ecu out and split to check for corrosion and did alittle bit of resoldering. Went to open the tailgate for the tools - cannot open battery disconnected. Connected it got the tools, put the ECU back. Turned on ECUScan and the ECU is not present. Reseated the ECU and realised I had removed and replaced the ECU with power on. So it is not a check now it is a full repair job.
When it is running again I will post record of actions to make the job of removing steering wheel easier - promise & probably to guides.
One thing that is going to happen when waiting is the white dials are going in. I have them on my bench and every now and again look at the instructions and say this looks too easy but I will give it a try. I think you need the steering column naked to fit the White Dials easy. At least you can make a good pic of the cluster for needle position.
Could be a nearly new car if I can find the immobiliser.
Thanks for all info posted on previous thread.
Stilo JTD just 04.
