multihull
Member
stilo 1.9jtd estate.
Immobiliser light came on and engine woill not start.
Roadside repair gave "key not being recognised" and then got me home.
Used registered ECUScan with 5 digit security code. Got mine when getting spare manual key (£15) + the rest for key and fitting.Over .£100 in total).
Body computer selected matching scanned body computer (Marelli MF), selected adjustments, selected Remote Control, entered Security Code, followed instructions through to complete. No errors shown.
Turned engine off and on - still hadd immobiliser icon and still no start.
Went through same process to the three options: Activstion lights (changes the response to key fob selection. Disabled it after putting security Code in. This to check adjustment working. Used the remote to lock and unlock car - no flashing lights or beeping so Security Code correct. Repeated process and enabled it.
Went through same process to get remote control immobiliser released.. No joy.
Request: Am I doing something wrong trying to get key recognised?
If not is the next step replace ECU. Presume that though I am working on the Body Computer it is all part of the ECU. And a replacement Ecu is needed. I cannot see anything else that is likely to not release the immobiliser.
Would appreciate someone confirming plan or pointing me in right direction.
Thanks to any response.
Bernie
Bernie
