Technical Left front wheel suspention knocking
Aruro
Geneva
Hello all!
Here are the symptoms:
Every time when turning right and passing over a small step on the road (like the join between two road patches or small curb) there is a knock in the left front wheel.
Sometimes this knock can be heard at start when releasing transmission pedal.
Am I correct in thinking that the problem should be with CV joint?
Suspension gurus please help :)
Lift the car up and try moving the wheel forward or any direction if you have movement thats your whishbone (you can try and locate which bush needs to be replaced but i found that its easier to change the whole thing )also check the droplink dont have any play by trying to move it with your hand by pulling and pushing.
I had knocking sound coming from drivers side and it was my whishbone that needed to be replaced, at the same time I did the rod ends and drop links. Now the ride is smooth and quite.
Could be the mount at the top of the strut under the wing. I had this on my 306. Never bothered foxing it as I was scrapping the car so turned up the stereo.
